What causes the build process to try and compile .js files?
Someone tried to use my unit testing framework and it wouldn't build. When I looked at the log everything worked well until near the end where there werethese entries. I've elided just one of them here for brevity.
m68k-elf-gcc -O2 ...2 -ohtml\scripts\SupportScripts.o ..\html\scripts\SupportScripts.js
m68k-elf-gcc: ..\html\scripts\SupportScripts.js: linker input file unused because linking not done
Which indicates eclipse is trying to compile the javascript files. Anyone know why?
k1mgy
Re: What causes the build process to try and compile .js files?
Post by k1mgy »
At some point along the way (I am the culprit here) I had installed Mylin Javascript Development support. This was done as there were some dependencies I needed to satisfy with version control integration (GALILEO).
I removed the support for Javascript and the problem disappeared.
Of course, a new one has taken its place.
./m
