Using NNDK 24 RC2, I am trying NBEclipse for the first time with our legacy application that runs on the SB72.
It is mostly working. I can set breakpoints, trigger breakpoints, and single-step at the source level. Very nice.
The problem is the Eclipse Debug view only indicates three threads (tasks), and our application has fourteen tasks. I can only single-step the source for the three tasks that actually appear.
Netburner TaskScan sees all fourteen tasks.
If I comment out one of the three tasks and rebuild, Eclipse Debug shows different tasks, but is still limited to three.
Do you recognize this symptom? Any suggestions?
Jim
NBEclipse Debug view only showing three of fourteen threads
Re: NBEclipse Debug view only showing three of fourteen threads
I figured it out.
After posting the question, I recalled a similar issue in Feb 2006 using Netburner GDB/Insight.
From my Feb 2006 notes, the problem then was that the precompiled debug Ethernet driver was built by Netburner with UCOS_STACKCHECK disabled, and using it with an application where UCOS_STACKCHECK is enabled had side-effects including including GDB breakpoint location confusion.
I disabled UCOS_STACKCHECK for our application build just now, and the NBEclipse Debug view shows all of our tasks and I can single-step the source properly. Success.
However, I would like to build our application with UCOS_STACKCHECK enabled. Is the precompiled debug Ethernet driver available for NNDK 24 RC2 built with UCOS_STACKCHECK enabled?
Jim
Jim
