ResponseRedirect
cmo
ResponseRedirect
Post by cmo »
Folk:
I'm sure someone has solved this. How can you redirect a user using a functioncall, but without a post function? Whenever I run this code I don't get a redirect, I just see the header output. I use this all the time on asp/php server side scripting. I'm trying to demonstrate this on a SBL2e.
for example, if on a page there is a functioncall:
<!--FUNCTIONCALL gotonewpage() -->
to the function
void gotonewpage(int sock, PCSTR url){
RedirectResponse(sock,"index.htm");
The output on a browser is:
HTTP/1.0 302 Redirection Location: index.htm
(followed by whatever else was in the HTML)
Again, this works fine in a post function. But, how can you force a redirect without using a post? Thanks in advance.
greengene
Re: ResponseRedirect
Post by greengene »
i'm not sure what problem you are seeing, but i redirect all the time
from GETs and the expected redirected page is displayed.
i am doing this in my own GET handler that was set with
SetNewGetHandler().
Not as easy on the SBL2E it uses a whole differnt web server scheme than the normal platforms.
The proper way is to put a functioncall in the head section of the web page and then do a refresh meta tag.
See:
http://webdesign.about.com/od/metatagli ... 80300a.htm
