Hi All,
I've gotten two PK70s and noticed the user Status leds are opposite in color between the two.
If one PK70 responds green to LED1_GREEN for instance the other PK70 will show *red*.
Assembly documentation problem? At least the two leds on each (Status 1 and Status 2) are consistent. If one shows green for a green command, the other will as well. If it responds red to the green command, the other will as well.
A bit of a problem if trying to use the LEDS to communicate anything by color!
MRC
