Is there a known limit on how large a project can be to run with the debugger? I am running into a problem after recently adding some code where the debugger always jumps into OSTaskIdle and will not step through code.
However, all of the tasks, including the new code, are actually running fine.
Symbol/Code Limit On Debugger
talexander
Re: Symbol/Code Limit On Debugger
To reply to my own question, it looks like the debugger stopped working because I rebuilt the system files with UCOS_STACKCHECK enabled, so that I could dump task stack data.
So, does anyone know why turning this on disables proper operation of the debugger?
