How to use "make load" on the command line
jpelletier
Post by jpelletier »
I can use the command "make" on the dos prompt (windows 10), but "make load" needs a target and target host.
How do we specify these? How do I specify my netburner IP?
Re: How to use "make load" on the command line
Do you want to do this interactively, or is this part of an automated build script?
So 3.X or 2.X?
if 3.X then set the environment variable..
set DEVIP=10.1.2.3
(User your board IP)
then make load will work...
For 2.X tools... a bit more complicated...
If the autoupdate tool remembers the last IP pointed at...
when you shut it down and restart...
Then it will just work...
IE point autoupdate at the board once, close autoupdate and then make load will work..
If that does not work (has to do with registry permissions) you can run as administrator and that will work.
Will post the no admin solution for 2.X in a minute I need to test it first.
For 2.x tools
set TARGETIP="10.1.2.3" (Its possible you should leave off the quotes.)
jpelletier
It's Netburner version 3.3.0
I use make load on the command line.
Setting the TARGET_IP variable worked on Linux. Thanks!
