Fast interrupt and assembly language
loinchg
Post by loinchg »
I need to update a design based on RabbitCore 3xxx, i have many code that must be executed at a fast periodic time (119 micro secs).
Almost all my code is made with assembly language.
The question is: Could i use MOD5441X to substitute RabbitCore, application has; two 1200 baud serial ports, ethernet, web-based configuration and eigth led indicators ?
Thanks, Martin.
Re: Fast interrupt and assembly language
Hello Martin,
Thank you for considering our products. Yes, the MOD5441x family can easily do those functions, and at a significantly faster speed than the rabbit. We have had a significant number of people porting from rabbit to our platform.
Best regards,
Tom
Written in C the external interrupt response time should be <2usec. With work you can make it less than 1usec.
How much work does the interrupt need to do?
