I am trying to rebuild the system libraries. I am getting the following error:
make: 0 [main] rm 3668 open_stackdumpfile: Dumping stack trace to rm.exe.stackdump
[clean] Error 5 (ignored)
I have no clue about this. Please help in this regards
Thanks in advance
stack dump error
Re: stack dump error
Hi There,
Sorry to hear that you've run into a bump. I have a few questions that should help to get you on the right track:
1) Which version of the NNDK are you currently using?
2) Are you building from NBEclipse or the command line?
3) Did you install a newer version of the NNDK over an older one?
4) Which platform are you trying to develop for?
Kind Regards,
Jon
Kind Regards,
Jon
1) I am using NNDK version 2.8.5
2) I am building from NBEclipse
3) Yes, previously, I used NNDK version 2.6.2, now, I am using NNDK version 2.8.5
4) I am trying to develop for the platform MOD5270B.
Thanks & Regards,
Giri Prasad N.
Thanks & Regards,
Giri Prasad N.
Hi Giri,
When you installed the new version, did you rename the old version to a new folder or completely delete it? Or did you install the new version on top of the older one? Weird things can happen if you try to install a new version over the old one, and the old version needs to be renamed or removed completely.
Kind Regards,
Jon
Kind Regards,
Jon
Hi Jon,
I have completely uninstalled the older version. Also deleted nburn folder completely and then installed new version.
Thanks & regards,
Giri Prasad N.
Thanks & regards,
Giri Prasad N.
