'417 Changing Switched/Independent mode without reboot?
sblair
Post by sblair »
Guessing this one is mostly for Dan. Looking through the "MOD54417-Multi-Intf" example I see that flipping between Switched and Independent Modes requires doing a full reboot.
Is there any possibility of changing between Switched and Independent Modes without having to do a full reset? I've got a use case where depending on what I'm doing I need to somewhat dynamically change between the modes and I hate having to jerk the rug out from under the user right in the middle of them doing something. I'd rather be more graceful with it if at all possible.
Scott
Re: '417 Changing Switched/Independent mode without reboot?
Noted. Looking into this one today...
