SPI Bus Initialization
When I initialize the SPI bus, I configure the clock and data to be high when inactive. However,
after initialization the clock stays low until I write to a device. Then it stays high thereafter
when idle. The problem is that the first device I try to initialize on power-up never gets initialized
because the clock starts off with the wrong polarity. If I initialize twice it works, but that seems like
a kludge.
I tried setting the clock high during SPI initialization, but whether I set the clock high before or after
SPI initialization, it doesn't work. Is there something else I can do, or just do the 2-transfers at power-up?
This is for a Nano54415 using v2.8.1.
DSPIModule SPIM( DEFAULT_DSPI_MODULE );
void spiInit()
	memset( spiTxBuf, 0, SPI_BUF_SIZE );
	memset( (void *)spiRxBuf, 0, SPI_BUF_SIZE );
	Pins[SPI_CLK] = 1;
	// Setup I/O pins for SPI bus.
	Pins[SPI_CLK  ].function( PIN_31_DSPI1_SCK	);	// SPI Clock
	Pins[SPI_SIN  ].function( PIN_33_DSPI1_SIN	);	// SPI Data In
	Pins[SPI_SOUT ].function( PIN_35_DSPI1_SOUT	);	// SPI Data Out
	Pins[SPI_CS0  ].function( PIN_15_DSPI1_PCS0	);	// SPI Chip-Select 0
	Pins[SPI_CS1  ].function( PIN_37_DSPI1_PCS1	); 	// SPI Chip-Select 1
	Pins[SPI_CS2  ].function( PIN_39_DSPI1_PCS2	); 	// SPI Chip-Select 2
	Pins[SPI_CS_EN].function( PIN_20_GPIO				); 	// SPI Chip-Select Enable (Not Used)
	OSSemInit( &DSPI_SEM, 0 );	// Initialize Semiphore for SPI bus.
  SPIM.Init( 2000000,		// Baudrate
								0x08,		// BitSz
								0x00,		// CS
								0x0F,		// CSPol
								0x01,		// ClkPol
								0x01,		// ClkPhase
								TRUE,		// DoutHiz
								0x00,		// csToClockDelay
								0x00		// delayAfterTransfer
	SPIM.RegisterSem( &DSPI_SEM );
	Pins[SPI_CLK] = 1;
ecasey
Re: SPI Bus Initialization
Post by ecasey »
Which way are the transfers going? and Is it the same for all devices?
ClkPhase means different (opposite) things depending on the direction of transfer.
You may need to change ClkPhase if the direction of transfer is different for different devices.
Ed
