MOD54415 TimerTick
for everything else
jediengineer
MOD54415 TimerTick
Post by jediengineer »
So a long time ago, I found a bit of HTML in the factory demo that called the system for a tick count which would display the number of seconds that the system had been running for (TimeTick/TICKS_PER_SECOND) - I found the HTML code, but for the life of me I cannot find any reference to the function it calls for some reason. I need to store a DWORD of the total time the system was turned on for, can't find a reference to the system timer. Can someone point me in the right direction? Thanks!
sulliwk06
Re: MOD54415 TimerTick
Post by sulliwk06 »
I believe there is a Secs variable you can use.
jediengineer
I couldn't find a "Secs" variable, but I did find this in utils.h:
extern DWORD GetPreciseTime( void );              // Gets the time tick since system start at a higher
                                                  // resolution, depending on the platform:  0.868-us for
                                                  // MOD5234/70, and 1.929-us for MOD5282
From what I gather, it's keeping a tick count, each tick being 1/20th of a second? At least for the MOD5441X platforms... the header didn't specify anything for the MOD5441X family. If I'm wrong, someone please fill me in... thanks!
Nope, that's not what GetPreciseTime does; it gets the sub-tick time from the hardware timer and returns the total hardware counts. This has a lower rollover than simply tracking TimeTick.
'Secs' is the name of the number of seconds since boot, it's declared as a VDWORD, or 'volatile unsigned long', inside 'ucos.c'. It is declared on line 62 of 'utils.h'
To add to Dan's comment...
TimeTick is the number of ticks since boot.
From utils.h....
extern VDWORD Secs; // Number of seconds since system start
extern VDWORD TimeTick; // Number of time ticks since system start
jediengineer
Thanks guys - appreciate it. Looks like what I was looking for! Apologies if that was too simple... I completely missed that when I looked in utils.h...
