How to Fix APP Header failed error on MOD54415
nicobari
Post by nicobari »
I uploaded a code to my MOD54415 and I got an error that says APP header failed. I believe it is something wrong with my code. How do I recover from it. I tried alternate boot but still cannot recover from APP header failed error. I tried uploading factory demo code while recovering from the error. I would appreciate any help in this matter.
TM
Re: How to Fix APP Header failed error on MOD54415
How are you doing the upload?
Serial port or Network?
I'd suggest that you use the autoupdate tool.
Also note that you want the myproject_APP.s19 file not the myproject.s19 file.
Please provide some more details on exactly what you are trying to do...
Also is this in your hardware on in a NetBurner Carrier board?
Unlike other netburners if you plug the MOD54415 into hardware that corrupts the data bus you will boot to monitor but fail to load the app....
with the message you have received...
Other netburners won't boot at all in that situation...
nicobari
Post by nicobari »
Just an update, I fixed the netburner on the development board and reuploaded the code and it worked this time. So I guess it was hardware problem.
Thanks again for the advice and the help.
Regards,
TM
