I made a few small changes to the operating system code (just simple gpio output in ucos.c). I recompiled all of the code successfully, however now I'm not able to debug. Whenever I try and go into debug mode I get the following error:
C:\nburn/lib/FatFile.a C:\nburn\lib\DBdebugLibrary.a -Wl,--end-group -oLedTest.elf
m68k-elf-g++: C:\nburn/lib/DBNetBurner.a: No such file or directory
Time consumed: 2035 ms.
Is this file supposed to be generated upon system compilation? I'm pretty sure it was still there before I recompiled the code.
Debugging on MOD54415X
Re: Debugging on MOD54415X
If you did a make clean on the system libraries, that file will have been erased. You'll need to do a debug build of the system libraries to fix this. Perhaps one of the other users (Tod or Forrest come to mind...) can tell you how to do this through Eclipse. As for doing it on the Command Line (which I use) you'll want to enter the following commands:
This is assuming that your NNDK install is located in C:\nburn; if its somewhere else, change the first line to match.
cd C:\nburn\system\
make debug
cd ..\MOD5441X\system
make debug-Dan
Thanks Dan! That worked perfectly!dciliske wrote:If you did a make clean on the system libraries, that file will have been erased. You'll need to do a debug build of the system libraries to fix this. Perhaps one of the other users (Tod or Forrest come to mind...) can tell you how to do this through Eclipse. As for doing it on the Command Line (which I use) you'll want to enter the following commands:This is assuming that your NNDK install is located in C:\nburn; if its somewhere else, change the first line to match.Code: Select all
cd C:\nburn\system\ make debug cd ..\MOD5441X\system make debug
I thought the debug files would have been generated through a "make all".
Ahh, that is not true. 'all' is generally a special target in a make system that will build all make targets in their standard configuration. Likewise, 'debug' is generally a special target in a make system that will build all make targets in their debug configuration.
