Mod54415 Factory demo -confusion
jediengineer
Post by jediengineer »
Hey Netburner staff - can you clarify something? This is in the webfuncs.cpp file:
* On the MOD-DEV-70, the switches are on J2 connector pins:
* 8, 6, 7, 10, 9, 11, 12, 13 (in that order). These signals are
* Analog to Digital, not GPIO, so we read the analog value and
* determine the switch postion from it.
BYTE ReadSwitch()
static BOOL bReadSwitchInit = FALSE;
const BYTE PinNumber[8] = { 7, 6, 5, 3, 4, 1, 0, 2 }; // map J2 conn signals pins to A/D number 0-7
BYTE BitMask = 0;
Which pins are they actually mapped to? Does it follow the schematic diagram or does it follow the pin numbers in the array? I will assume that it follows the schematic, because the program reads the voltage across the ADC, but if the program is written to read different pins, how is it working?
