MOD54415 random C/C++ question
jediengineer
Post by jediengineer »
I've never had to do this before, so I need a little help. I'm writing a piece of code that has "default" variables stored in array A[x] and I need to store used defined variables in array B[x]. But once the power is terminated, I lose all variables in array B[x] because they are user defined. Is there a way to define an array, write to it, and have it retain it's data even after restart or power-off? I realize that this may mean writing into the program memory - is that possible? Thanks
Tony
Re: MOD54415 random C/C++ question
See the C:\nburn\examples\SaveUserParameters example for using onboard flash.
jediengineer
Oh! The flash is non-volatile?
jediengineer
Thanks!! I can't believe I didn't see that!!
