I have been working with some graphics libs, and it causing eclipse to crash due to out of memory errors. Not In any way related to how much memory I have in my computer as I have 4 GIG installed.
When I go to the help on this, it says to use "eclipse -vmargs -Xmx<memory size>" when I do that it does not work. Does anyone know another way to kick it up ?
Increasing the heap size.
Re: Increasing the heap size.
See:
NBEclipse is running low on memory, how do I fix this
at:
http://wiki.embeddedethernet.com/Suppor ... se_Related
Sounds like you may have tried this, but when I stepped up to the 1024M parameter it fixed a similar problem.
at:
Sorry not to add this to previous post. I seem to remember Tod Syncor has a screencast about this too:
http://www.syncorsystems.com/Engineerin ... issues.htm
or http://www.syncorsystems.com/Engineerin ... r/tips.htm
Thanks Ridgeglider!!!
That was perfict!
That was perfict!
