HTTP GET, Content-Encoding: gzip
ddeham
Post by ddeham »
I need to download a web page from another embedded device, and parse some data from that page. I tried using similar code that has worked before. However, this particular device sends out the web pages encoded with gzip.
Here's the http header:
HTTP/1.0 200 OK Date: Wed, 28 Jun 2006 13:30:04 GMT Server: Boa/0.94.13
Connection: close
Content-Type: text/html
Set-Cookie:
Is there a way to tell the server not to gzip the reply?
If not, what is the easiest way to decode the gzip encoding in a Netburner MOD5282? I found the gnu gzip source code but I'm having trouble importing the code into my project. Is there a stand-alone "inflate" source code module available somewhere that would be easier to import? HELP!
Dan
Re: HTTP GET, Content-Encoding: gzip
ddeham wrote:Hi,
Connection: close
Set-Cookie:
Dan
The server has the file stored in zip, so I do not think you can request a different encoding. At one point a customer stated that he was able to get the LZO and miniLZO libraries to work with our code. More info at
http://www.oberhumer.com/opensource/lzo/. Please note that this does not create zip files, but does offer compression. I have never used this, but you may be able to get it working with some experimentation.
