Browser hangs after software reboot
greengene
Post by greengene »
this appears to be new(?), but now when i do a ForceReboot(), an open browser session,
e.g., IE7, Firefox, the window just hangs waiting.
when i netstat -a it shows sockets still established with the NB.
i don't think this used to be the case. i need to open a new browser instance in order
to connect to the NB - a new tab won't do it.
anyhow, can i force the NB to close the sockets, i.e., send a FIN, before I reboot?
will doing a close() on each socket's fd send the FIN?
how can i stop new connections while i'm going through my processing leading up to the reboot?
StopHttp() is just a stub so i don't think that is any help.
KillStack() is described in the manual as "do not use".
any help will be appreciated.
greengene
Re: Browser hangs after software reboot
Post by greengene »
close() on each socket worked.
odd that the reboot after a software upload didn't have the problem.
some day i'll look and see what that is doing differently than me.
If no data is in the pipe when you reboot, then you do need to close the sockets first. Otherwise there is nothing in the tcp/ip protocol to tell the web browser the netburner (or any other device) went away, so it leaves the sockets open.
greengene
Post by greengene »
maybe NB can sell their KeepAlive code to MS ;)
actually, it no longer is broken, i.e., i'm loading the same versions of
our app that i did earlier and now they aren't hanging the browser!
MS is so much fun!
