Problem with dspi for MOD54415 with new NBeclipse IDE
So I have two different computers A and B. A has an old version of Netburner Eclipse IDE (2.6) when dspi.h and dspi.cpp were not included by default. So I downloaded them from the forum and installed it and compiled my code and it worked perfectly. Now for the new computer B I downloaded NBeclipse IDE 2.6.4 which has dspi module included by default and compiled my previous code and when I uploaded it to MOD54415 it just gives me -1 value but when I go back and recompile the same code from the computer A and upload it to MOD54415 it works again. I haven't tried swapping the dspi.h and dspi.cpp file between Computer A and B. Is this a bug in NBeclipse 2.6.4 or I am doing something incorrectly. I will appreciate any help in this matter.
Regards,
TM
Regards,
TM
Re: Problem with dspi for MOD54415 with new NBeclipse IDE
Do you have any way of doing a file compare to see any differences between them?
Have you made any changes to system files that were not duplicated on the second computer?
I copied the .cpp file from computer A to computer B. To be honest I don't know how to do a file compare other than visually looking at each other. For the second computer I just downloaded NBEclipse 2.6.4 and installed it (I didn't modify any system files).
TM
TM
nbeclipse can do a file compare, but I don't remember how. I bet Tod knows.........
The easiest way to do a file compare is to have two projects in the same workplace. In the (typically) right hand Project Explorer window select one file. Then press CTRL and click on the second file (usually in a different project, but not necessarily). Right click, to reveal the menu. Scroll to "Compare With" --> "Each Other". This works for a file by file compare. It is also possible to compare an entire project. Instead of selecting individual files, select two project folders! The tool will show all the files that are different, and allow you to expect each individually. Very useful. You can edit each of the files too upon finding differences.
By the way, you can also compare with previous versions, as long as they'e been worked on in the current workspace. This makes changing files in the "Compare With" feature a bit less risky since you can always revert to an earlier version. See also the "Replace With" menu option next to the "Compare With: feature.
There are lots of "Diff Editors" that will do these things outside Eclipse, but the Eclipse tools work pretty well.
nicorabi,
Can you give some more detail as to what is giving you the '-1'? Each of the dspi calls returns an completion status (DSPI_OK, DSPI_BUSY, DSPI_ERROR), but none of these is '-1'. Something seems wrong with your description. Can you post the code section that is giving you problems?
Sorry for the late response I was tied up in solving the issue and was running back to computer A to upload the code. I am attaching my section of code below.
I am initializing my DSPI as
and when I print IMU1_raw or IMU2_raw I see -1 in all of them
I will do a file compare and see what I get.
Thanks for the help,
TM
DSPIStart(1,IMU_command,IMU1_raw,24,NULL);//IMU1
while(!DSPIdone(1)){};
DSPIStart(3,IMU_command,IMU2_raw,24,NULL);//IMU2
while(!DSPIdone(3)){};Code: Select all
void initDSPI(){
DSPIInit(3,2000000,16,0x01,1,1,1,0,0,0);//initializing SPI
DSPIInit(1,2000000,16,0x01,1,1,1,0,0,0);//initializing SPI
}I will do a file compare and see what I get.
TM
Also I checked the return values of DSPIInit and DSPIStart and they both are 0 which is "STATUS OK" as defined in dspi.h
So I really don't know what is incorrect.
Regards,
TM
Regards,
TM
Arg... I'm sorry, I should have known this issue when you said you were using 2.6.4, but I keep thinking that's the latest; it's not :/
There's a problem with the DSPI driver prior to 2.6.5 where it will shut down the bus a byte or two early during transfers that has since been fixed. You can grab the 2.6.5 beta from support to fix this.
Thanks, Just finished installing the 2.6.5 and it works.
TM
TM
