I'm getting a spurious interrupt/exception in my code very infrequently (unfortunately). In most of the posts I've read, this happens when the interrupt mask register is manipulated without changing the interrupt priority level in the status register. Can the same thing happen when the peripheral interrupt enable register is manipulated? For example, here are my interrupt enable and disable calls. The interrupt of interest is the external interrupt 3, which is set as a level-sensitive interrupt. Processors external to the NB module can pull this line low to request service:
void EnableProcInterrupt (void)
{ // Enables the processor interrupt line (IRQ3) through the edge port registers of the Coldfire. This allows the other processors to
// interrupt the NB.
USER_ENTER_CRITICAL();
sim.eport.epier |= IRQ_3_INTERRUPT_ENABLE_BIT; //IRQ3 active.
USER_EXIT_CRITICAL();
iprintf ("\n *************** Proc interrupt ENABLED."); // NEXT: DEBUG
void DisableProcInterrupt (void)
{ // Prevents the processor interrupt from occurring.
sim.eport.epier &= ~IRQ_3_INTERRUPT_ENABLE_BIT; //IRQ3 inactive.
iprintf ("\n *************** Proc interrupt DISABLED."); // NEXT: DEBUG
Here is a dump from the latest trap. The faulted PC seems bogus (IE: points to code not in the meter update task, which is the one running):
Exception Frame/A7 =0211B66C
Trap Vector =???? (Hex):0x18
Format =04
Status register SR =2000
Fault Status =00
Faulted PC =0203DBAE
A0=021196CA A1=021196AA A2=8000E276 A3=8000E256
A4=02067A3C A5=000000A5 A6=0211B688 A7=0211B66C
D0=00000236 D1=00000800 D2=0000FFFF D3=00000003
D4=00000001 D5=000000D5 D6=000000D6 D7=000000D7
SR=2000 PC=0203DBAE
The OSTCBCur current task control block = 2000074C
This looks like a valid TCB
The current running task is: Meter Update#34
Idle#3F|Ready | |02067AE4,02065EE8,0
Main#36|Ready | |02038E60,02034284,02065EE8,0
TCPD#28|Semaphore |0E42|02067746,02076228,02065EE8,0
IP#27|Fifo |007F|02066C24,0206AA70,02065EE8,0
Enet#26|Fifo |0039|02066C24,0207BD1A,02065EE8,0
Loud Calc#32|Mailbox |0000|0206743A,0203FFD2,02065EE8,0
Front Panel#31|Timer |000B|02067ACA,02028CCE,02065EE8,0
Grpx Dispatch#33|Fifo |0000|02066C24,02026A7C,02065EE8,0
Dolby Update#35|Timer |000F|02067ACA,020492BE,02065EE8,0
Meter Update#34|Running | |0203DBAE,0203DC24,02065EE8,0
Serial Mdata Parse#30|Semaphore |0000|02067746,02045822,02065EE8,0
Watch Dog#01|Timer |0020|02067ACA,0200368E,02065EE8,0
Thanks for the help.
Brian
