Hey all,
Does anyone know where I can find the GPIO voltage and current specs? I've been going through all the manuals, including the freescale manual, but I can't seem to find it! I know the voltage level s go from 0-3V, but what it the mack output current? And if the port is a sink instead of source, how much current can it sink? Thanks all!!
Tony
MOD54415 GPIO specs
Re: MOD54415 GPIO specs
Go to C:\nburn\docs\FreescaleManuals
and have a look at MCF54415DataSheet.pdf
I did check there - I must have missed it. I'll check again. Thanks!
Ok, so I've checked the manual, and maybe I'm missing it (probably if it's staring me in the face) - I just need to know at what voltage does the pin register as high input and what is the input impedance? Same for output. Can someone point me directly to a spec? Thanks!!
See Page I/O Electrical Specs pg23-24 of C:\nburn\docs\FreescaleManuals\MCF54415DataSheet.pdf
