Where is the MOD54415 mechanical drawing
Where can i find the MOD54415 mechanical drawing at ?
Re: Where is the MOD54415 mechanical drawing
The 54415 products are still pre-release. The drawings are in progress, and will be posted as soon as they are complete, which will be near the ship/release date. For the MOD54415 that would be by the end of this month, May 31. It should be identical to the MOD5234, but please wait and verify once the drawings are released.
PCB outline, mouting holes and Ethernet connector are identical to mod5234...
If you need the precise position of the microsd card connector I can try and dig that up.
Thanks, that is all i needed.
i assume the SD card pins are using the SDHC_xxx pins listed on the Pinout ?
