I ran the 5270 factory program (straight out of the box). The DHCP server assigned an IP address, and I viewed the demo website over the LAN.
The console was observed over USB port (as UART0 to USB to COM3) with MTTTY.
Next, I setup a project for "hello world" and ran the example C file (sampleapp) in the 5270 directory. The "Hello World" displayed properly in MTTTY.
I added a few lines to the C program, and attempted to re-flash. Although I can observe the settings over MTTTY (COM3), the 5270 appears invisible to NBEclipse. NBEclipse cannot find or flash the 5270. I looked through the documentation in an attempt to flash the 5270 over USB, but appears to be no provision to flash over USB. Is the IDE really this weak? Serial flashing is a time-honored tradition.
In the console (MTTTY), some options were attempted to prompt NBEclipse to flash over TCP, such as DL and FLA. The FLM reports disabled.
How do I flash the 5270?
Help: Flashing a program into the 5270
Re: Help: Flashing a program into the 5270
After a bit of work, I can now download and flash new firmware manually in the console (MTTTY) using TFPT.
This seems to be a round-about way, but is working for now.
UPDATE: I tried to TFTP the "factory demo" program, and the TFTP fails after 747 out of 813 blocks.
The command was:
The error was:
The command was:
NFLA FactoryDemo_APP.s19
Netburner MOD5270B Monitor V1.0 Jun 6 2008 13:45:30
HELP for help
nb>NFLA FactoryDemo_APP.s19*****************************************************
******TFTP Open Fail
Decomp Failed
No Valid app
nb>
From the main.c program of sample app:
/* IMPORTANT - This example is the smallest possible C "Hello World". As such,
it does not support the autoupdate or network download capability as do
the other examples. Once you have loaded this example application, you will
need to perform a serial download through the debug serial port to put
a different application in your NetBurner device.
So by running that program you would not be able to see it ever again in ipsetup or any other network find utility. From that point you need to do a serial download through mttty using fla, not any of the network protocols.
- Chris Ruff
- Contact:
To the best of my knowledge, even this teeny program doesn't stop IPSETUP from conversing with the netburner high port, IPSETUP is talking with the netburner library.
AutoUpdate, however only works if you expressly place the AutoUpdate line in the main.
The app doesn't call InitializeStack(), so I don't think any network services will run, including the one that replies to IPSetup.
