Can write/read to PINK, but cannot see on network
Community forum for discussion and support of the PINK product and development kit
Re: Can write/read to PINK, but cannot see on network
ipset will find all the NBs. They are listed in the "select a unit" right hand window. The ones configured for DHCP say so, but also list the assigned IP. In the screen shot below, notice that 2 NBs are DHCP
'd. Select the one you want to configure, edit the "NDK Settings" then click "Set->"
It could be the unit's flaky but it sounds equally probable that you could have a suspect cable (assuming you were using the same blue cable for all these tests).
