MyDoPost not being called
BMillikan
Post by BMillikan »
I have a form on a web page with some other simple HTML elements and a dynamically updated page from the Netburner board. When I press the submit button on my page, the page updates but the function is not getting called. I have verified that the SetNewPostHandler() is getting called. Has anyone else run into a problem like this?
Brian
greengene
Re: MyDoPost not being called
Post by greengene »
probably easiest if you post your html page rather than us guessing what is in it.
first guess: on form, is "method=post"?
I don't think the post handler has anything to do with a function getting called if you use the FUNCTIONCALL tag. If you are trying to call a function from a post handler, you normally need to parse the post data and call your function if appropriate. Not really enough info in your question to narrow it down.
greengene
Post by greengene »
well, depends which "the function" is being talked about.
BMillikan
Post by BMillikan »
Yes, the method="post" was the solution. I forgot to add that to the HTML tags. It was apparently defaulting to the GET method.
