Editor how to's with Eclipse
mmk-tsm
Post by mmk-tsm »
I have recently upgraded from Dev C to Eclipse, and really like the power of this Eclipse editor but cant figure out a couple of things:
1. Is there a way to get an undo and redo buttons on screen?
2. Can I change the highlighting of matching braces format to make it more like the way Dev C did it? I.e. select one brace and the matching one shows up.
3. Is there a way to get a button for indenting and unindenting? I know you can go into the edit option and do it - but that's cumbersome.
TiA,
Mike.
Re: Editor how to's with Eclipse
For indenting code, Eclipse does that automatically most of the time. If I am reformatting code I highlight/select the code I want to indent/unindent, then use the tab key.
Another very cool feature I like is when I am typing a function or variable name I can use control-space (hit together) to autocomplete the name or bring up a list of names if there are more than one.
I've never figured out how to add items to the toolbars but you can easily add keyboard shortcuts. Undo already has Ctrl-Z assigned. The fast way to get to the Keys prefs is to hit SHIFT-CTRL-L twice. The first time brings up a list of shortcuts the second one lets you add new ones. I have Redo set to CTRL-Y. I find keyboard shortcuts more useful than buttons.
Also if you're new to Eclipse there are a couple of HowTo articles on the wiki. I have a number of blog posts related to Eclipse and NetBurner many of them also have embedded screencasts.
mmk-tsm
Post by mmk-tsm »
Tod,
have you removed the screen casts? I see two locations, 1 & 2, but no video.
I had some problems with Eclipse and building last week. In the process of getting sorted, I have lost the very useful feature of being able to see values of variables simply hovering over them - any idea where I enable this option please.
The screencasts are still there. I'm not sure which blog post you were looking at exactly but the Eclipse tips part 1 video and the Eclipse Tips part2 can be viewed directly on youtube if you want. I'm not sure about your specific question (is it a problem in source, the debugger, macros etc.) but check the settings under:
Windows->Preferences->C/C++->Editor->Hovers
