I've found documents (Mod5270 GPIO Configuration) that indicate there is 1 dual use 16 bit IO set.
DATAL and DATAH.
We need two 8 bit inputs with two different clocks.
So this should setup the GPIO
#include "sim.h"
#include "gpio5270.h"
void UserMain( ... ) {
unsigned char datal =0, datah = 0;
int bcontinue = 1;
// Data Pin Assignment Register. Set all sixteen pins as GPIO.
sim.gpio.par_ad &= ~GPIO_PAR_DATA;
// Data Port Data Direction Register. Set signals PDATAL0 and PDATAH8
// as GPIO inputs.
sim.gpio.pddr_datal = 0;
sim.gpio.pddr_datah = 0;
// DMA Timer Pin Assignment Register. Set the three DMA timer output
// signals as GPIO.
sim.gpio.par_timer &= ~( GPIO_PAR_DTOUT1 | GPIO_PAR_DTOUT3 );
// DMA Timer Port Data Direction Register. Set the three DMA timer
// output signals as GPIO outputs.
sim.gpio.pddr_timer |= ( GPIO_PIN_DTOUT1 | GPIO_PIN_DTOUT3 );
while ( bcontinue ) {
// Set a timer pin high
sim.gpio.podr_timer |= ( GPIO_PIN_DTOUT1 | GPIO_PIN_DTOUT3 );
// Data Port Output Data Register. Set GPIO signal PDATAL0 low and
// PDATAH8 high.
datal = sim.gpio.podr_datal;
datah = sim.gpio.podr_datah;
sim.gpio.podr_timer &= ~( GPIO_PIN_DTOUT1 | GPIO_PIN_DTOUT3 );
This is intended to ask for help/guidance using this.
If you can provide guidance, it would be a big help.
TIA
Chuck
