I'm just about almost there posting data from a serial port onto a webpage, but
Eclipse is reporting errors when I try to dynamically display the captured variable on the webpage!
There is no Eclipse compiler error when I run this sample code below, so far so good!
WriteHtmlVariable(fd, TimeTick/TICKS_PER_SECOND);
Embedded on WebPage <!--VARIABLE TimeTick/TICKS_PER_SECOND -->
However if I substitute this bit of simple sample code with my own variable there is a compiler error?
Eclipse doesn't really tell me, where I have gone wrong?
int AnyValue=24; ; // I’ve declared my own value of variable here
WriteHtmlVariable(fd, AnyValue);
Embedded somewhere on my WebPage <!--VARIABLE AnyValue -->
This generates the following from the compiler
In file included from htmldata.cpp:3623:
HtmlVar.h:10:23: warning: no newline at end of file
htmldata.cpp: In function 'int DoHtmlVariable(int, WORD)':
htmldata.cpp:3629: error: 'AnyValue' was not declared in this scope
Time consumed: 4078 ms.
Grateful for any insight into this puzzle thanks -It may have something to do with mixing extern C++ functions with C generated parameters?
WriteHtmlVariable(fd, AnyValue);? Compiler Error??
Re: WriteHtmlVariable(fd, AnyValue);? Compiler Error??
On closer inspection, I have previously written code called
<!--FUNCTIONCALL PassMyValue --> [embedded within a HTML page]
, with its corresponding call function
void PassMyValue (int sock, PCSTR url)
which will pass the desired variable to the webpage, and I don't get any more errors from Eclipse.
Morale of the story - there is more than just one way to skin a cat!
You didn't mention where you declared
I think you need to declare it in your code, but also reference it in htmlvars.h. If its not in htmlvars.h, the web services can't see it.
In the final solution you came up with you can also write out an entire javascript object in case you want to capture the state of a bunch of variables with a single function callback. You would write out something like
There is an example of this in my recent post on AJAX, and don't be put off by the fact that the post was primarily about AJAX, the whole section that deals with the above topic ( it's the section about machineState in my code) has nothing to do with AJAX it is just a simple Function callback. Once you start passing back valid JSON objects you'll find it is a lot easier to start using those objects in code.
var someObjectName =
VariableName1: ValueForVariable1,
VariableName2: ValueForVariable2,
etc....
LastVariableName: ValueForLastVariable
Very much appreciated for suggesting editing the htmlvars header file - it definately worked, no more compiler errors!rnixon wrote:You didn't mention where you declared
Coming originally from a Borland C compilier environment, I have had it too easy so far compared to mastering the more complex Eclipse environment
Yes Tod appeciate your advice, it does sound like an elegant well crafted solution with the Ajax implementation.tod wrote:In the final solution you came up with you can also write out an entire javascript object in case you want to capture the state of a bunch of variables with a single function callback. You would write out something like ..........
I may consider this single function callback option sometime later when building a weather station perhaps, where there is a requirement for lots of external disparate variable sources to display and monitor at once.
For the time being, I'm just getting familiar with the web based FLASH Actionscript where the underlying TCP socket calls can be passed through the NB module.
