Updating SNMP for v3.x Project
Post by SeeCwriter »
I'm upgrading SNMP used in projects built with v2.x tools to work in projects built with v3.x tools. The SNMP files are C files. During compilation header file <file/udefs.h> is included, which throws an error:
C:/nburn/nbrtos/include/file/udefs.h:35:8: error: expected identifier or '(' before string constant
extern "C++"
The error is caused by statement "extern "C++" at the top of the file, line 35:
#ifndef NB_BARE_METAL
extern "C++"
#include <nbrtos.h>
#endif
The same file in the v2.x tools only has this statement at the top of the file:
#ifdef __cplusplus
#endif
Would this change to the v3.x file work:
#if !defined( NB_BARE_METAL ) && !defined( __cplusplus )
extern "C++"
#include <nbrtos.h>
#endif
Re: Updating SNMP for v3.x Project
Actually, my idea is not going to work. What do you suggest?
Who's SNMP package are you using?
DMH Software.
The do have a port to our 3.x platform. However, we do not have their code or do the integration here. Have you tried contacting them? I have not seen extern commands like that before.
I'm not sure what you mean when you say "I have not seen extern commands like that before." They are in your file. undef.h is not a DMH file.
The DMH implementation of SNMP saves configuration data to the module's flash memory. So it includes the headers for being able to use the fs_ functions.
I've contacted DMH about this and they are looking into it also.
udef.h is not one of ours...
Sorry, I misspelled the file name. It's udefs.h, located in nburn\nbrtos\include\file.
That must be put in there by the DMH installer, it is not one of our files. Here is a pic of the directory of a standard 3.x install:
Screenshot 2022-11-30 125034.jpg (30.19 KiB) Viewed 23639 times
I should have paid attention to file header, it's actually a file from HCC Embedded. The file is in subdirectory of nbrtos\include\file. I think it must installed when NNDK is installed.
It's only included in four files from HCC Embedded: api_f.h, fsf.h, fsm.h, port_s.h. And DMH includes file fsf.h when it needs to use the Flash memory on the module to store SNMP configuration data.
At one point I thought I could just edit udefs.h to remove the "extern c++" term at the top, but later in the file it defines a mutex type as OS_CRIT, but OS_CRIT uses classes, which won't work when compiling a C file, which is what all DMH files are. In v2.9.5 of the tools, udefs.h defines the mutex as an unsigned long.
