NNDK-2.8.6 - EFFS Not Working
ecasey
Post by ecasey »
Using NNDK 2.8.6 with a Mod5270B on a Mod-Dev-70 the file system for the SD card on the Mod-Dev-70 board does not see any files. I checked the SD card and it is fine. In my code I get f_chdrive() returning F_ERR_INVALIDDRIVE. After trying another Mod5270 and then another Mod-Dev-70CR board with the same results, I tried running the EFFS-FTP example in the Examples/StandardStack folder. It gives a traps on a segmentation fault at f_chdir('/'); (line 184) in ftp_f.cpp. It shows the Flash Card Memory usage correctly, but the Display Directory comes up empty.
My code worked fine in NNDK2.8.3. I did a roll back to make sure. I didn't see anything in the notes for NNDK2.8.4, 5 or 6 that looks like you touched the file system.
Can you give me some guidance on this?
Ed
Jon
Re: NNDK-2.8.6 - EFFS Not Working
Post by Jon »
Hi Ed,
You will want to replace the fatfile.a from your previous NNDK release with what is currently in the lib directory. This is a known issue that we are working to resolve for the next release. Sorry for any inconvenience it has caused you!
Kind Regards,
Jon
ecasey
Post by ecasey »
That worked.
Thanks Jon.
Ed
Post by SeeCwriter »
Jon,
I have the same issue with 2.8.6, and I'm confused by your answer. Is the "previous NNDK release" v2.8.3 or v2.8.6? Because it seems as if you are saying to replace fatfile.a in v2.8.3 with the same file from v2.8.6.
The FatFile.a library has not changed throughout all the 2.8.x revisions, so you can copy it from any of those releases.
If nothing has changed, why would replacing FatFile.a solve the problem?
Somehow that file was corrupted when the release was created.
