I have installed netburner2.6.2 and trying "rebuild all system files". Build is getting halted with the error: "/bin/sh: m68k-elf-gcc: command not found".
Please help me regarding this.
facing an error: "m68k-elf-gcc: command not found"
Re: facing an error: "m68k-elf-gcc: command not found"
First of all, that is quite an old release. You may consider updating the tools at support.netburner.com. This will likely fix this issue, as older releases may not have set the proper NBROOT and PATH variable in NBEclipse. This means that NBEclipse may not be able to find our toolchain (such as m68k-elf-gcc). Question: Are you projects building properly? Is this error only occurring when you try to rebuild the system files?
