Build Error "two resources of the same name"
barttech
Post by barttech »
I've somehow scrambled things up with my tools, so that when I try to clean a project, I get:
**** Rebuild of configuration Release for project 41557 ****
Build error
Generated resource conflict:
two resources of the same name: /41557/Release/41557.s19
generated by different tools
tool1: GNU ELF Objcopy
tool2: NetBurner Compcode
I've gone to the ToolChain setting and it shows both of these tools, but (unless I click "Allow All Changes") it doesn't allow me to remove ObjCopy. If I override and remove ObjCopy it will seem to clean, but it won't compile when I make changes to the source code: "Nothing to Build". I've tried deleting 41557.s19 but it still complains, but doesn't create a new one.
Some history:
I'm trying to get the eTPU QD functionality to work. I was getting compiler errors after changing to set3.h from NN_ETPU_sets.h in EPTUInit.cpp, so I set it back and restored all the original files and still had a similar problem. So I tried setting all the settings to their defaults, didn't help, then I tried re-installing Rel24_rc2. I'm no longer sure just when this particular "two resources" error cropped up, but I can't get it to go away and I can't move on. Any suggestions?
Sam
Re: Build Error "two resources of the same name"
Bad things will happen in any project manager when you copy non-source files around. What happens if you create a new, empty project, then import only your source code files: .cpp, .h, html. ?
barttech
Post by barttech »
If I do that the problem goes away! Thanks. Now to try to get QD eTPU stuff working w/o trashing my project again.
Sam
