IP Setup can't find my eval board
Posted: Sun Aug 22, 2010 8:23 am
by acreque
I just purchased a NNDK-5272-KIT and ipsetup can not detect it. I have both my laptop (host) and MOD5272 connected to an ethernet switch, which is connected to my router, which is connected to my cable modem. All ports on the switch work, and so does DHCP, because I can connect my laptop to any port on the switch and it works fine. I know the MOD5272 is alive because Mttty works. Please help.
Re: IP Setup can't find my eval board
Posted: Mon Aug 23, 2010 2:48 am
by v8dave
What does the output on MTTY show?
Does it show that it got an IP address from DHCP?
Can you paste the output here?
Posted: Mon Aug 23, 2010 9:19 am
Your firewall is probably blocking port 20034, which ipsetup uses to communicate with the module. As a quick test, try temporarily turning off your firewall completely and see if you can view the device.
