SBL2e-100IR Web site question
Posted: Sat Aug 29, 2009 12:53 pm
by seulater
Can you load in a different web site into the SBL2e-100IR ?
and if so, how much flash does it have.
Re: SBL2e-100IR Web site question
Posted: Mon Aug 31, 2009 12:16 pm
by lgitlitz
Currently there is no option to load a custom application or website to the SBL2e. There is a good possibility that a programmable version of this product will be released in the near future but this is not yet 100%. The programming environment is pretty different from our other networking products due to the extremely small (32K) space available in RAM, there is a much steeper learning curve for this product.
Flash space is rather large compared to the RAM but it still will not be able to accommodate large web sites. The default application that ships has a web page that is about 46K in size. This default application also leaves about 70K of unused space in flash and less then 1K of used space in RAM. The total size of flash available for user application is about 224K so you can probably get a web page of 150K or so if you remove some of the functionality provided by the default application.
-Larry
