Seriously, guys?
Re: Seriously, guys?
Hi KE5FX!
I apologize for the frustration with these lines. This was part of the new config_*_limit functionality to allow developers to easily define reasonable and/or custom validations and error messages on config objects, but I miscommunicated with a senior engineer and allowed these values to remain in code and make their way into a place that probably caused you problems: what's reasonable for an end user to type into a web form is not the same as how DBL_MAX/DBL_MIN is used globally.
In our next release the following changes will be made to config_obj.h:
--- a/nbrtos/include/config_obj.h
+++ b/nbrtos/include/config_obj.h
@@ -52,6 +52,7 @@ is required to save changes to flash memory.
#include <string.h>
#include <utils.h>
#include <limits.h>
+#include <float.h>
void ShowTree();
@@ -2415,8 +2454,6 @@ class config_uint_limit : public config_uint
-#define DBL_MIN INT_MIN
-#define DBL_MAX INT_MAX
* @brief A config_double with minimum and/or maximum valuesRe: Seriously, guys?
Great to hear it wasn't intentional. I was starting to question my own text editor.
As an aside, I'm sure you know that DBL_MIN is the smallest positive normal double while INT_MIN is the largest negative int. That has tripped me up before, and it looks like it may have caused additional confusion here as well.
Yep, caught that one too! Some of this will become moot as I also discovered that `name` is required for proper operation and rather than change the argument order I'll just remove the default values for min/max/step. Which shouldn't be a big issue since the whole purpose of the _limit objects is to define custom limits.
Thanks for the feedback!
