Can't get to work with SBL2e
Posted: Fri Feb 11, 2022 1:43 am
Hi all,
Sorry for the long post
I am a newbie in NetBurner stuff, evaluating if I can turn SBL2e into an Ethernet to I2C converter.
But I'm stuck in the very beginning...
Issue #1
Connecting UART0 to my PC's COM1 (yes it has a DB9 serial port, haha!), I can't get the monitor to respond. I only read:
Waiting 2sec(s) to start 'A' to abort
No matter if I press A, a, A+Enter, a+ Enter, AAAAAAAAAAAAAAAAA or whatever, the menu + nb prompt simply does not display as the tutorial says.
Except for one of the 5 SBL2e I purchased for evaluation, which displays the monitor menu and prompt without pressing any key.
Anyway I tried typing the supposed monitor commands and none of the 5 SBL2e did anything. No Reset, no Boot, no Help: nothing.
Issue #2
In addition, I tried using IPSetup.exe to fix the SBL2e's IP on 2 devices. Both are now NOT detected by IPsetup.exe. I just set the IP address, no mask or anything else, I guess that's the bricking cause). They don't pong when I ping their (supposed) IP address. I tried reprogramming the factory app to them with MTTY, but I assume that, as I am not getting the nb prompt, I can't get them back to life.
Besides that, is it possible to reprogram the IP settings only? I did not find anything about this in the docs.
Issue#3
I tried twice to program the modules via NBEclipse, one module through UART with the original application and another one via network, with a custom app I made (which I assume has tons of bugs), but none of the tries actually downloaded anything, both program downloads timed out.
Any tip on any of my three problems?
I have only one untouched SBL2e now, if it gets bricked too, I will have to dismiss Netburner as an option for my application, but I assume I may be doing something obviously wrong - though I just cannot imagine what!!
Issue #1
Issue #2
Issue#3
