Launcher Won't on Vista
Posted: Thu Mar 26, 2009 4:07 pm
by dpcons
I'm using Vista Business SP1. When I try and launce my app from Eclipse (or use Auto-Update from Eclipse) I get the following error: Error starting process
Exec error:Launching failed.
IPSetup fails to launch from Eclipse also.
I can run from the desktop and I can also run Auto-Update from the desktop and all is well.
Any thoughts?
Re: Launcher Won't on Vista
Posted: Fri Mar 27, 2009 9:03 am
by Forrest
Older versions of the NNDK may not work under Vista. Any release from the past year should be fine though. What version are you using? You can check in c:\nburn\release_tag
Posted: Fri Mar 27, 2009 10:19 am
by dpcons
I'm using Version 2.2.
Posted: Fri Mar 27, 2009 10:26 am
by Forrest
That release should work fine under Vista.
3 things to check...
First, update your Java JDK to the latest release.
Second, are you installed in the default c:\nburn directory (others are ok, but lets ensure that it works with default config ).
Third, do you have system administrative rights to run apps under your Vista installation? Is that really useless User Account Control feature enabled? Try disabling it.
Posted: Fri Mar 27, 2009 10:42 am
by dpcons
I'm using JRE 6 Release 12. I'm using the default c:\NBurn directory and yes, I have administrative rights. I'll try to disable the UAC later today and let you know.
Posted: Thu Jul 30, 2009 12:34 pm
by dpcons
Sorry, forgot to get back. It is indeed the UAC. I disabled it and now Lanucher works fine. Inconvenient, but workable.
Posted: Mon Dec 14, 2009 10:48 am
by rjt
Actually, you can make it work without turning off UAC. Use Windows Explorer to go to the directory where NBEclipse lives (usually c:\nburn\NBEclipse). Right click on the NBEclipse.exe file and choose Properties. Choose the Compatibility tab. At the bottom choose "Run as Administrator" and click OK.
This will run NBEclipse as an administrator, but turnig off the UAC will do that for every program instead of only the one that requires it.
Richard Threlkeld
Software Innovation
