MOD5270 GPIO help
Posted: Tue Mar 24, 2009 11:06 am
by nageshpolu
I have a question regarding the Netburner’s MOD5270 GPIO. I made one of the digital I/O pin to be an input, but I can see a voltage of 3.3V at the pin. Is there way that I don’t see any voltage on the pin if it set as input.
Please help me with this issue.
Thanks.
Best regards,
Nagesh Polu
Re: MOD5270 GPIO help
Posted: Thu May 28, 2009 10:42 am
by liugera
Hello mate,
what you should do is to wire the input pin to a signal... 1 or 0... or any value between 0 and 5 volts if you are using the analog inputs...
greets :D
Posted: Thu May 28, 2009 9:15 pm
by yevgenit
GPIO pins have a weak pull-up to +3.3V. Adding your own pull-down resistor will bring the floating voltage to almost zero. 1 kOhm is a good value.
Regularly, you don't need such a pull-down, due to the driver of your signal source is strong enough to overkome the on-chip weak pull-up.
nageshpolu wrote:I have a question regarding the Netburner’s MOD5270 GPIO. I made one of the digital I/O pin to be an input, but I can see a voltage of 3.3V at the pin. Is there way that I don’t see any voltage on the pin if it set as input.
