MODM7AE70 Canbus
Posted: Thu Mar 05, 2020 1:39 am
by wroos
I've recently started working with the MODM7AE70 and I would like to use the CAN bus functionality to interface with external components. I'm not able to find a single reference to any CAN bus code in the examples folder, nor can I find the canif.h I see referenced in some threads here on the forum. Is there a driver available for using CANbus on the MODM7AE70, has anybody been successful in getting this working?
Re: MODM7AE70 Canbus
Posted: Thu Mar 05, 2020 3:24 pm
If you do not see an example that you are looking for, please contact NetBurner support directly. They may have examples that are not published.
Posted: Wed Sep 02, 2020 4:59 am
by Anguel
I am also confused. After reading this article on your blog I also got the impression, that CAN is ready to use on your modules:
https://www.netburner.com/learn/the-can ... n-can-you/
So what is the current situation? How about reference designs with CAN transceivers?
Anguel
Posted: Wed Sep 02, 2020 5:48 am
Pretty much any can tranceiver will work...
CAN TX, CAN RX power and ground, four wires...
Try searching for a SN65HVD230
I found one on a break out board form Amazon....
Just 4 wires.
The MODM7 has a CAN examples in the latest 3.X releases...
Posted: Wed Sep 02, 2020 9:44 am
by Anguel
Hm, I have the 3.1 and don't find anything about CAN, now I looked at the 3.3 files and don't see anything CAN related there:
https://www.netburner.com/NBDocs/Develo ... files.html
Thanks for the info about the transceivers.
Posted: Wed Sep 02, 2020 10:13 am
nburn\examples\\PlatformSpecific\MODM7AE70\CanExample
Posted: Thu Sep 03, 2020 3:16 am
by Anguel
Thanks Paul! I found it in the new v3.3 release.
