I would like to use the Visual Lint Eclipse Plugin and maybe later also some other Eclipse Plugins with NBEclipse (NNDK v3.1).
I installed the plugin into the plugins subfolder but it does not seem to run or maybe I am missing some step?
Is it possible to use NBEclipse with plugins or what is the recommended way in 2019?
I only find some very old posts regarding Eclipse plugins here in the forum.
Thanks in advance,
Anguel
Visual Lint Plugin with NBEclipse?
Re: Visual Lint Plugin with NBEclipse?
Update: In the meantime I managed to install other static code analysis plugins, e.g. for cppcheck and this works. So maybe there is some issue with this particular plugin...
