ReadS19ApplicationCodeFromStream over SSL (HTTPS)
dnishimura
Post by dnishimura »
Has anyone tried using ReadS19ApplicationCodeFromStream over an SSL stream? Is it even possible?
Re: ReadS19ApplicationCodeFromStream over SSL (HTTPS)
Yes its been done. Should just work....
Using the nburn\examples\standardstack\web\postapplicationupdate with ssl server should do just that...
dnishimura
Actually I wanted the update to originate in the other direction... have the Netburner do a HTTPS GET for the s19 file. I was able to get it working. The only difference was that I read the HTTPS stream until the end of the HTTP header and then pass the FD to ReadS19ApplicationCodeFromStream. Unfortunately, it wouldn't work if the HTTP Transfer-Encoding is chunked, so I'm only able to do it if the web server serves it up not chunked.
Thanks for pointing me to the example.
