Format issue
Format issue
This seems to be related to v2.7.4, since the same code compiled with v2.7.3 works correctly.
short myval = -16;
iprintf("Myval: %d, 0x%x\r\n", myval, myval );
Output: "Myval: --16, 0xfffffff0"
Declaring "myval" as an int doesn't change the output.
Using "printf" doesn't change the output.
Update: Using "sprint()" and "siprintf()" produce the same output.
Re: Format issue
Correct: Known bug. Contact support for the fix.
