NNDK Release 2.7.4 (January 2016)
Posted: Thu Jan 14, 2016 1:13 pm
NNDK 2.7.4 beta release is now out and available for download on the NetBurner tools download page. Please report any issues in this thread or directly to support by submitting a new ticket at http://support.netburner.com.
# Release 2.7.4 (January 2016)
## New in this release
* DHCPD
* Added ability to choose DHCPServer start address at runtime.
* Examples
* Added NANO54415 ADC example
* Added MCF5441X Pulse Generator/Counter example using DMA timer
* Added FTPClient to SBL2e
* Added IrigB example to MOD5234 & MOD5270
* Added Ethernet to I2C example to SB70LC
* Added Firmware update example for NBWifi.
* Added ClearUserParameters example
* MCF5441X
* Added promiscuous modes to MCF5441X Ethernet drivers.
* Added Peripheral Clocks header to MCFf5441X sources
* Platform
* Added SB800EX platform support
* RTC
* Added ability to use any I2C module to MOD5441X for external RTC clock
* SBL2e
* Added 485 driver to SBL2e
* SSL/TLS
* Added support for SHA2 certificate signatures.
* Added OS X support for Cert generation
* SysLog
* Added ability to SysLog via specific interface using SysLogVia()
* TCP
* Added ability to listen on specific interface
* Tools
* Added mac address reporting to find.py
* WiFi
* Added support for SB70LC
## Corrections in this release
* CB34EX
* Added support for GetPreciseTime
* HTTP
* Fixed httpstricmp to properly handle strings that are substrings of the input before the '?'
* Fixed truncation issues for static file server >32K in web server
* MOD54417
* Fixed buffer leak if you call send when in switch mode
* MOD5441X
* Added watchdog callback support to mod5441X flash routines
* NANO54415
* Monitor no longer set unused UART pins to UART mode on boot. To get this fix, contact support
* EFFS Standard - fixed init so it only happens once, halves boot time
* RTC
* Fixed off-by-one error in month on MCF5441X RTC
* SSL/TLS
* Added timestamp when sending SSL Mail
* Moved SSL/TLS to separate library (cryptolib.a)
* Fixed time-out issue with non default tick rates
* Added a single large buffer to TLS buffer allocation to handle overlarge Negotiations without falling back to malloc
* Fixed altname support for certificate verification
* Changed examples to use compiled in certs not using NetBurner specific formating
* Fixed issue with FIN terminated SSL sessions causing a TCP socket leak
* Fixed session reuse bug which increases SSL web server connection performance 4X
* SBL2e
* Fixed http hangup when socket was reset with pending tcpprintf data outstanding
* Fixed escaped chars on SBL2E web server
* System
* Fixed multiple error in printf family functions
* Fixed AutoIP when main interface has no IP addr
* TCP/IP/UDP/DNS
* Made ephemeral port usage consistent across different uses. Fixes a DNS through NAT lookup failure
* WebClient
* Fixed WebClient example to deal with chunked encoding
* Added TLS support to WebClient
* WiFi
* Only run DHCP if connection succeeds
