MOD54417 \TA pin usefulness as GPIO
Posted: Thu Sep 03, 2015 11:01 am
Can GPIO pin PA4 in the MOD54417 actually be used? I had it set as a GPIO input with a low state at power up. It somehow interferes (acting as \TA?) with the program loading from flash (a debug build). MTTY output shows a message indicating a bad load. If I remove the PA4 pin from the peripheral holding it low, my application starts normally. We are using the FlexBus in 8 bit mode, using CS5, if that makes any difference.
Ray
Ray
