CAN bus intermitent operation
Posted: Wed May 27, 2015 9:35 pm
I have two NANO54415s on a dev carrier boards connected together via CAN. One has an app generating messages, the other receiving those messages. My issue is that the one generating message usually works fine if I upload firmware to it, but not if I do a cold boot or press the reset button.
If I send this code to it, it reboots and starts sending messages 90% of the time. However, if I then pull power and reconnect it, or press the reset button, it will usually boot up and report a -5, which means CAN Timeout. If I press the reset button a few more times, eventually I will get it to send data.
I did come across this thread, which appears to be similar.
http://forum.embeddedethernet.com/viewt ... f=5&t=1167
That mentions reading the CAN registers, but the example is for flexcan, and I think the multican is some newer version for the 54415. I don't see anything about reading registers in the multican.h file.
Lance
#include "predef.h"
#include <autoupdate.h>
#include <dhcpclient.h>
#include <netinterface.h>
#include <ucos.h>
#include <string.h>
#include <serial.h>
#include <taskmon.h>
#include <multican.h>
#include <pins.h>
void UserMain( void *pd );
const char *AppName = "CAN Generator (Dev Board)";
#define CAN_MODULE (1)
void UserMain(void *pd) {
OSChangePrio( MAIN_PRIO );
EnableTaskMonitor();
Pins[20].function(PIN_20_CAN1_RX );
Pins[22].function(PIN_22_CAN1_TX );
if (MultiCanInit(CAN_MODULE, 250000, 0, 4) == CAN_OK) {
while (1) { // Infinite loop to listen for and send CAN messages
OSTimeDly(2);
char buffer[8];
siprintf(buffer, "%i", Secs);
int status = MultiCanSendMessage(CAN_MODULE, NormToNbId(106), (PBYTE)buffer, strlen(buffer), 50);
iprintf("_%i", status);
} else {
iprintf( "CAN init failed\r\n" );
}I did come across this thread, which appears to be similar.
Lance
