Page 1 of 2
Ethernet port going to sleep
Posted: Tue Feb 03, 2015 6:17 am
by Don
We are using PK70 and we are having issue in the field where the ethernet port goes to sleep. we have not seen this in our lab until resent with some iprintfs statements determine that the IP packets are not getting IP level of code a warmrestart fixes the issue. Look though the forum there was issue back a few years but I don't see what was causing the issue or how to solve the issue.
Don
Re: Ethernet port going to sleep
Posted: Tue Feb 03, 2015 10:19 am
What is the PK70 connected to? If its a laptop, could the laptop be going to sleep? An easy test would be to connect the PK70 to a standard switch and see if the behavior changes. Note that some green/eco friendly switches have a sleep feature too.
Posted: Tue Feb 03, 2015 10:26 am
by Don
The devices that are going to sleep are connect to switches the type of switches I don't know because the devices are at customers locations
Posted: Tue Feb 03, 2015 10:34 am
Is this static or DHCP address?
Does it still have a link light?
Can you see it with ipsetup on the same LAN Segment?
One possible fault I've seen is that the device is given a DHCP address with long lease time (say weeks)
then at night someone turns off all of the network gear and computers in the facility... (except the netburner)
Then in the morning they fire things back up and the netburner still has its DHCP lease,
but the server after a reboot has given the address to another device...
The cure for this was that if the NetBurner ever lost communications with the server it was polling it rebooted itself...
Posted: Tue Feb 03, 2015 10:48 am
by Don
DHCP disable fixed IP addresses
Posted: Tue Feb 03, 2015 10:52 am
by Don
Link light still on
using wireshark there is no response to ping
Remove cable our code see no link plug cable in code see link so still able to talk to phy
waiting for device in lab to go to sleep and then I will dump that status and command reg of phy to see if anything change.
Posted: Tue Feb 03, 2015 11:31 am
What NNDK code revision?
Can you report the free buffers....
#include <buffers.h>
WORD GetFreeCount();
Posted: Tue Feb 03, 2015 11:34 am
Do you have any UDP recieve processing going on?
Anything connected to the console port...
IE if you ggetting a trap or fault and the hit 'A' to abort message comes up...
could the thing attached to the console port be sending an 'A'
(The way to fix this is to set the console port to a differnt baud rate than the "Device" and then set the baud rate of the device with an openserial call and explicit baud rate.)
Posted: Tue Feb 03, 2015 12:52 pm
by Don
running 2.5.2
nothing connected to console port
The device that we are running in lab also has a TCP/IP over PPP connection to cellular device I'm able to make a TCP connection to the cellular device our code allows the user to make a TCP/IP or ping devices on the Ethernet connection. unable when the ethernet is lockup.
Posted: Wed Feb 04, 2015 8:23 am
There are literally millions of these deployed in the world.
Given than in the last 72 hrs I've had two people (you and one other) report almost exactly the same scenario,,,
(Differnt NNDK code versions) but otherwise similar story.
Ethernet just stops and link light is still on....
One of the few things that can take down the ethernet system is running out of buffers
in this case you see a declining free count before it goes dead.
Is it possible to add diagnostics to report the value of
This answer would basically divide the possible fault tree in half, ie a buffer problem or
some stack or task locking issue.
