ADC zero crossing interrupt
Posted: Wed Mar 12, 2014 1:04 pm
So I've been trying to set up the AtoD converter on the NANO54415 to trigger an interrupt at every zero crossing. And it seems to not be triggering. I have verified that I am getting positive and negative values from the result register on channel 0. I'm wondering if I have the interrupt vector set up right. The reference manual says that I add the source number to 64 for INTC0, and 128 for INTC1, but it doesn't say anything for INTC2 which is where I find ADC_ZCSR for source 34. I assume its just another 64 up, but something isn't working.
Can anyone tell me what I'm doing wrong?
Edit: I have also confirmed that the appropriate bit in the zero crossing status bit is being set. And I have tried using the force interrupt register sim2.intc[2].intfrch |= 0x0004; and the interrupt isn't being called. So does that narrow it down to the SetIntc call?
void ZeroCrossingInterrupt()
zeroCrossingCount++;
void CreateZeroCrossingInterrupt(int fd)
if(!zeroCrossingInterruptCreated)
volatile WORD vw;
//initialize ADC, taken from periodic AD
sim2.adc.cr1 = 0;
sim2.adc.cr2 = 0;
sim2.adc.zccr = 0;
sim2.adc.lst1 = 0x3210; //Ch 0....
sim2.adc.lst2 = 0x7654; //ch 7 in result 0..7
sim2.adc.sdis = 0; //All channels enabled
sim2.adc.sr = 0xFFFF;
for (int i = 0; i < 8; i++)
vw = sim2.adc.rslt[i];
sim2.adc.ofs[i] = 0;
sim2.adc.lsr = 0xFFFF;
sim2.adc.zcsr = 0xFFFF;
sim2.adc.pwr = 0; //Everything is turned on
sim2.adc.cal = 0x0000;
sim2.adc.pwr2 = 0x0005;
sim2.adc.div = 0x505;
sim2.adc.asdiv = 0x13;
//end of init
if(SetADCZeroCrossingISR(ZeroCrossingInterrupt) == INT_NO_ERROR)
dprintf(fd,"\r\nZero crossing interrupt created");
zeroCrossingInterruptCreated = true;
dprintf(fd,"\r\nfailed to create zero crossing interrupt");
INTERRUPT(adc_zc_int_isr, 0x2200 ) //analog to digital zero crossing interrupt
ADC_ZCFunction();
//Write 1 to respective bit in ADC_ZCSR
sim2.adc.zcsr |= 0x0001; //reset interrupt
int SetADCZeroCrossingISR(void (*isrPointer)())
if(ADC_ZCTaken)
return INT_TAKEN;
ADC_ZCTaken = TRUE;
ADC_ZCFunction = isrPointer;
sim2.adc.ofs[0]=0x07D0 << 3;//set mid point
sim2.adc.zccr = 0x0003;//set interrupt for any sign change on channel 0
SetIntc(INTERRUPT_CONTROLLER_NUMBER,/* interrupt controller 2 */
(long)&adc_zc_int_isr, /* Our interrupt function */
((INTERRUPT_CONTROLLER_NUMBER + 1) * 64)+34, /* The vector number is the interrupt source number plus the offset of the interrupt controller */ //source 34
2 /* priority.*/
//start reading AD input
sim2.adc.sr = 0xffff;
// sim2.adc.cr1 |= 0x0400;//enable zero crossing interrupt
sim2.adc.cr1 |= (ADC_CR1_START | ADC_CR1_LOOP | 0x0400);
return INT_NO_ERROR;
