NNDK Release 2.6.4 Beta for Windows and OSX
Posted: Wed Nov 20, 2013 10:53 am
NNDK 2.6.4 beta release is now out and available for download on the NetBurner tools download page. Please report any issues in this thread or directly to support by submitting a new ticket at http://support.netburner.com.
NNDK 2.6.3 has been elevated to stable status.
# RELEASE 2.6.4 (November 2013)
## New in this version
* Examples
* Added PIT timer for the SBL2E
* Adding wav_player examples to NANO54415 and MOD5441X platforms
* PK70
* PK70-232CR, -485CR, and -MMSCR devices now supported by secure factory app
* Serial
* Added SerialSendComplete(), which will check to see if all serial characters are sent
* System
* Added task time logging feature. To enable it, the system library needs to be compiled with the macro UCOS_TIME defined in constants.h
* Adding support in uc/os for handling OS_TCBs changing in size without recompiling debug Ethernet drivers. Allows for using stack checking with the debug driver
## Corrections in this version
* MCF5441X
* Fixed so that chip select mask values for DSPIInit did matches their description and behavior of the qspi driver
* Fixed multi channel i2c driver to not rely on DEFAULT_I2C_MODULE definition by replacing calls such as i2cinit with multichannel_i2cinit calls internally.
* MOD5441X
* Fixed pin_irq class error on IRQ6
* Modified pinio class to reflect hardware revision changes (J1-9/10, J2-17/18)
* SBL2e
* Documentation updated to more clearly state the 768 stack size value represents 32-bit values, not bytes.
* Fixed TCP Buffered connect error not clearing error variable
* SNMP
* Fixed error reporting issues
* Fixed getNext with null OID
* Fixed too big error so errors are properly reported and system does not hang
* System
* WriteHtmlVariable() fixed. Was writing last byte of MAC address incorrectly
* Fixed problem with incomplete transfers of static web resources
* Fixed DHCP discover on fast boot with lossy networks
* TCP
* Fixed scheduling issues with TCP which caused 1 tick busy waits in lower priority tasks
* WIFI
* Fixed error in AddWifiInterfaceWithName() which could case flash corruption with erratic power
