NNDK Release 2.6.3 Beta for Windows and OSX
Posted: Thu Jul 18, 2013 12:46 pm
by Forrest
NNDK 2.6.3 beta release is now out and available for download on the NetBurner tools download page. Please report any issues in this thread or directly to support by submitting a new ticket at http://support.netburner.com.
NNDK 2.6.2 has been elevated to stable status.
Anyone use MOD54415 or NANO54415 are recommended to use NNDK 2.6.3 due to processor latency bug fix mentioned below.
# RELEASE 2.6.3 (July 2013)
## New in this version
* Examples
	* Added Twitter Bootstrap example, a web css framework for UI features on web pages.
	* Added AJAX real time data graph example
	* Added example on SBL2E serial callbacks
* Github
	* Several examples open sourced and moved to github.com/netburner
* HTTP
    * Documented <!-- CPPCALL --> web function. Works like FUNCTIONCALL, but allows support for C++ functions
    * Added robots.txt to disallow search engine crawling of examples by default
* MCF5441X
	* Added DSPI driver and example
	* Added multi channel i2c driver
* NANO54415
	* Added SetDefPinUsage() to set default pin assignments
* SBL2e
	* Added serial callback functions to SBL2e serial drivers
* SSL
	* Added 4096 key support
	* Added RSA_RC4_SHA1 cipher
* System
    * Added FreeBufferList() utility function to free buffer list
    * Added init() and initWithWeb() utility functions. These functions provide standard initialization for apps
* TCP
    * Added NoBlockConnect() non blocking connect function
* Tools
    * MTTTY updated with better USB/Serial port support
## Corrections in this version
* Ethernet
    * Fixed maximum packet size error
* Examples
	* Fixed NTP app/example bug which reduced time accuracy
	* Fixed MCF54415 PWM examples for edge aligned PWMs bug to remove dead time
* MCF5441X
	* Fixed i2c default baud rate
	* IRQ Vector table moved in to SRAM from external DDR
	* Created unified i2cstruct definition, which allows a single type access to all i2c modules
	* Fixed critical processor latency bug which caused 0.5 ms processor hangs
* SNMP
	* Added ability to handle octet writes with embedded zeros
* SSL
    * Fixed TCP socket leak on SSL failures
* System
	* Fixed default timezone parsing so default daylight savings time is 2am, not midnight
* TCP
    * Increased speed of duplicate ack retransmission on a lossy network
* Tools
    * Fixed issue where IPSetup did not see multi interfaces that are not exposed to network
