Debugger won't launch on drive not equal to C
tpschmit
Post by tpschmit »
I installed 'NNDKSetup21_rc4a.exe' on drive O not C (don't ask -- long story). Everthing seems to work so far except when I attempt to launch debugger (see result from console below). How do I change the drive it uses?
Best,
Tom
Source directories searched: $cdir;$cwd
Warning: c:\nburn\system: No such file or directory.
mi_cmd_env_cd: Usage DIRECTORY
Quit (expect signal SIGINT when the program is resumed)
kill
mrchadwickusa
Re: Debugger won't launch on drive not equal to C
Post by mrchadwickusa »
I have a similar problem. Using Windows Vista and version 2p1rc4A of the NDDK on a PK70 module.
Trying to run the TFTP demo program in debug mode. I have added the debugger intitializtion as described in the getting started guide.
Compiles but then comes up with the error:
Failed to set program arguments, environment or working directory.
Unable to set working directory: mi_cmd_env_cd: Usage DIRECTORY
I have the default directory selected in the debugger configuration, which is the same as the run configuration, which works.
What am I doing wrong? I can't find an explanation of what that (mi_cmd_env_cd) is. An environment variable that needs to be explicitly set or what?
I've got my default workspace set to 'C:\Users\user\Desktop\DesignWork\Eclipse Workspace'
and I've tried making a project with the workspace in the 'C:\Nburn\examples\TFTP' directory, and it behaves the same both ways.
Mike Chadwick
tpschmit wrote: I installed 'NNDKSetup21_rc4a.exe' on drive O not C (don't ask -- long story). Everthing seems to work so far except when I attempt to launch debugger (see result from console below). How do I change the drive it uses?
kill
Is your installation in O:\nburn\system?
This should work. Have you tried doing this with the latest rel22_rc2 release? Same results?
mrchadwickusa wrote:I have a similar problem. Using Windows Vista and version 2p1rc4A of the NDDK on a PK70 module.
The CDT/Eclipse debugger does not work when spaces exist in the project name or workspace directory. This is an error from the default Eclipse release that has yet to be resolved. I suggest you move to a directory structure that does not contain spaces
mrchadwickusa
Hey thanks for that, that was the issue. I've been debugging using iprintf, so I'm looking forward to learning the debugger!
